The one shown is 2000 rpm at 56vdc, if you are not sure of any other motor it could be ran off of a 12v automotive battery and check the rpm, it would be proportional to the maximum rpm, IOW if rated at 56v/2000, 12v would result in ~430rpm.
You would need at least a 1.5Kva power supply for all three motors.
Any DC supply with this capacity would work, at least 70vdc, 72vdc would be fine.
Al.
