586,396 active members*
3,090 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fagor Automation > Fagor error code " No Spindle Speed Value "
    Jun 2013
    Hi people , i am learning to drive a Fagor 8T controller on my lathe but keep getting error code today " No Spindle Speed Value"
    I have spindle speed set already , its showing on the screen ( 400 RPM ) , it was all working fine yesterday but i have stuffed a setting and cant find which one
    The spindle will run okay in manual mode but when i try to start a canned turning cycle the spindle does a few turns then stops with that error message.
    The manual doesnt list a reason for it that i can find
    I also had another error code "072 following error Z" , i assume it means a coordinate i programmed in Z axis is incorrect but i cant see why ? i have the values entered with correct + and - where they should be
    Please tell me what "following error" means ?
    eg screenshot
    RPM 400 DIAMETER
    BEG X=000100.00 , Z= 000200.00
    END X=000090.00 , Z= 000100.00
    Dia 000090.00
    > 0000.300 N 00000
    24223
    Following Error Z means that there is something causing a lag or prevention allowing the Z axis to reach position or actually move.
    Can be a mechanical binding or open encoder.
    With most Fagor, the position can be set by parameter for either anticipated position or actual encoder posn. Set to encoder position and move the Z and see if the Z display changes.
    Al.
  1. Looking for some "high"er speed spindle ideas for my bf20 clone
    By GreatNorthGnome in forum Benchtop Machines
    Last Post: 06-28-2014, 08:57 AM
  2. "Error Tiggered Art Code 1" message
    By rewster in forum Machines running Mach Software
    Last Post: 01-14-2011, 08:53 PM
  3. Replies: 2
    Last Post: 04-09-2010, 04:56 PM
  4. "high" speed spindle with cad model
    By Thorpydo in forum Benchtop Machines
    Last Post: 04-21-2009, 11:38 PM
  5. My "Crazy" high speed spindle test
    By SScnc in forum Benchtop Machines
    Last Post: 04-21-2009, 01:16 PM
