586,991 active members*
4,054 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > I need a g-code simulator for basic sheet metal punching....
    Sep 2007
    Maybe some of you can suggest some solutions. I have a mature manufacturing system that I am attempting to modify for a customer. It's using an Amada turret to manufacture sheet metal products. Rather than consume sheet metal when testing my s/w changes, I purchased punchsim to allow me to do before/after runs with my changes. Punchsim works, but it leaves much to be desired - I'd like to be able to slow it down more so I can see what's going on... Perhaps single step through the gcodes...
    Most of the s/w sims I see have to do with 3d modeling and manufacturing, so it's overkill.
    Any suggestions?
    cg
    You could take a look at WE-CIM from Wittlock Engineering http://www.wittlockeng.com/
    Independent CNC Programmer
    www.independentcnc.com
    My mission is to share CNC programming innovations for a lifetime.
  1. G code simulator
    By millman52 in forum SheetCam
    Last Post: 11-20-2011, 08:40 PM
  2. Nc Code Simulator
    By Morgadoleo in forum Uncategorised CAM Discussion
    Last Post: 07-02-2009, 06:15 PM
  3. MASTERCAM X2 BASIC SETUP SHEET
    By mt15racing in forum Mastercam
    Last Post: 02-22-2008, 04:26 PM
  4. G-code simulator
    By Machinist16346 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-23-2007, 03:07 AM
  5. Basic Sheet Metal Work Needed
    By Mark30504 in forum Employment Opportunity
    Last Post: 10-09-2006, 04:55 AM
