587,035 active members*
3,383 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Inte200 MK4 Matrix control - Milling cutter EIA cutter radiusr compensation G41
    Jun 2013
    Morning all,
    First post on here, need help in getting our EIA programming G41 milling cutter radius compensation working correctly.
    We can get radius comp to work in mazatrol programs but not in EIA ?
    There are a number of parameters we have tried changing to see if we can get it to work but with no luck and we have also tried using various different EIA programming codes and formats, but with no luck. We have even tried calling the tool up in a Mazatrol program and jumping straight into an EIA program from it.
    Does anyone have an example of a programming format you use and works and the parameters that the machine has been changed to to get it to work properly?
    Our machine is an Integrex 200-IV S with Matrix control.
    Any help greatly appreciated,
    S
    Jun 2007
    87
    Not sure about the matrix control but the older mtpro has 2 sets of offsets. One is exclusive to mazatrol and the other one to EIA. Mazatrol offsets are on tool data page while EIA offsets/radius comp are on tool offset page. Kind of silly actually, having adjustments on mazatrol program, then you ran an EIA and all your offset adjustments won't get carried.
  1. Cutter Compensation
    By brenlee42 in forum Haas Mills
    Last Post: 01-30-2013, 12:50 AM
  2. Siemens Control - Cutter Compensation
    By donl517 in forum Fadal
    Last Post: 01-14-2013, 04:32 PM
  3. T SLOT MILLING CUTTER PACKAGE 5 (ON WALTER CNC CUTTER GRINDER)
    By dharschman in forum Toolgrinding / Toolgrinding Machines
    Last Post: 09-13-2010, 06:25 PM
  4. Cutter compensation????
    By Clawsie Machine in forum Cincinnati CNC
    Last Post: 11-13-2008, 08:19 PM
  5. Cutter compensation?
    By Tonenc in forum G-Code Programing
    Last Post: 11-03-2005, 06:53 AM
