586,655 active members*
2,070 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Milltronics Partner V Spindle Drive Shaft and Bushing
    A bearing spun on the splined spindle drive shaft in our Milltronics Partner V mill. Also, the bushing in the vari-speed pulley that rides on the shaft needs to be replaced. We contacted Milltronics and were told both parts are not available from them.
    Does anyone know of a someone that would have the parts we need?
    Please let us know!!
    Thanks!!
    chipsmom
    Jan 2011
    380
    The bearing will be a standard bearing, and should have it's part number located on the outer race. Can get the bearing from any bearing house. As for the bushing, if it's splined you should be able to get it also from a bearing house. I would recommend looking here:
    Motion Industries - Keeping Industry in Motion
    You may have to get one thats slightly larger on the OD and machine it to the size you need. If Milltronics doesn't have these parts for their machine, it may come to this. Or making the part yourself. Maybe someone else can add to this?
    Jul 2010
    548
    PM Me.
    Sportybob
