I understood what you meant with short reply... keep it simple
I've ran machines both ways G53, G28......... seems like I remember some machines using G30's and an odd M code to call machine coordinates.
Walking is highly over-rated
Random question, is that Mach 4 beta? Looks a lot different than my Mach 3.
Sent from my SGH-I337M using Tapatalk
Well, I ran off 8-different plaques, averaging 28-minutes each!
The tool change system is very efficient, but I had to order the spacer for my Kent Dust Shoe because the tools extend a 1/2" more with the tool holders!
Widgit
Thanks Widget, never even knew screensets existed! I've got them now, definitely an improvement.
Does anyone have any experience with the break function in the 2.2Kw spindles? Using several tool holders is great, but I have to wait forever for the spindle to slow down to change tools!
Widgit
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
Download 1
Grab the HY manual.
Ya gat the water cooled ver of the 2.2 I hope
Paul
Sorry for the typos
I see you got the water cooled.
I run auto radiator coolant ( Ph neutral) and a water fountain pump
some versions of the invertor were missing the RS 485 chip but can be dropped into the board .
Paul
If it's anything like the Hitachi you should be able to brake it a bit without an external resistor. I put the biggest tool I had in mine and kept adjusting the spool down speed until it didn't fault out with a DC rail voltage too high error. Takes about 4 seconds to stop from 24000 rpm. With a resistor that could be adjusted to a half second or less most likely.
Looks like PD015 decel time is what you want to adjust.
From memory I think the floor rpm is about 6K. The question is does the vfd go into snooze mode or keep the DC brake setting active?
I guess the ramp down setting is the first step.
The other issues I think is that the "Pause" in mach3 needs to be inserted into the macro to give the ramp down time to take effect.
Paul
page 31 and 32 of the Inverter.pdf has more info
You don't want to use a Pause in Mach3. Go to Ports and Pins > Spindle Tab, and set a value for CW Delay Spin Down. Mach will wait the delay length before resuming movement after the spindle is turned off.
Depending on when and where you turn the spindle off (M5), you may or may not need this. It won't have any effect on the VFD braking.
Gerry
UCCNC 2017 Screenset
Mach3 2010 Screenset
I HATE banner ads, they have destroyed this forum!
CNCZone now as cluttered as the Yahoo forums!
I've been trying for three days to log in, and get the same results from my I-pad or PC! The IPhone is a total failure to login, as it's screen is too tiny!
All I get are login errors!
Your submission could not be processed because the token has expired.
Please reload the window.
I'm using Tapatalk on android. I got sick of the banners. Maybe they have it or something like it on Apple. I would hate to see you leave because of it...
Sent from my LGMS769 using Tapatalk 2
https://adblockplus.org is nice
Paul
PS Dont go big widget, dont go ... ;-)
