586,560 active members*
3,484 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > Machine for Woodworking with 6 working motors heads 5axis.
    Jun 2013
    Hello,
    I am making CNC from old Copying machine. I used Solidworks to make most off machine drawings. These is no bottom part at drawing, and 5th rotation axis I attach photos. Need Help with everything, steppers, control system, constructing all axis. If someone could help it would be great. The constructions is totally balanced, good working machine. 3 axis is clockwise and 3 are counterclockwise.
    I can spend up to 6k Euros. For starting I don't want to change motors that exist, maybe later.
    My thoughts are to attach motors each side. For Rotation 5th axis install 1 motor, every wood part is rotating same time, by hand now For axis that controls turning to sides (left right) one motor, but don't know where and how to install it. For the axis with motors- 1 motor each side on axis, changing existing parts with new ones adjusted for motors install. Other axis is more problematic.
    All thoughts are welcome!
    Regards Dalius,
    Attached Thumbnails Attached Thumbnails Parts.jpg   1.jpg   IMG-20130531-WA0050.jpg   IMG-20130531-WA0051.jpg
    Jun 2013
    Questions:
    1. Will I be able to drill correctly with computer when most parts moves angularly not straight lines? What system can do it?
    2. Any suggestions how to install steppers?
    3. Possible calculation for choosing steppers?
    4. What Control board chooses?
  1. saleCNC laser engraving machine and CNC woodworking machine
    By zhangrui1588 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-08-2011, 09:54 PM
  2. 3 or 5axis Router Machine time in Perth, WA
    By Sadara in forum Employment Opportunity
    Last Post: 07-19-2010, 06:26 AM
  3. Heads up - Mini Machine sale
    By DareBee in forum Canadian Club House
    Last Post: 07-01-2010, 04:27 PM
  4. 5axis CNC desktop machine w/ Tool Changer?
    By Adam Baker in forum Benchtop Machines
    Last Post: 09-16-2009, 10:35 PM
  5. sell CNC Woodworking Machine,CNC Advertising Machine
    By zhangrui1588 in forum News Announcements
    Last Post: 05-30-2008, 02:43 PM
