586,100 active members*
2,713 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > MIST COOLANT SELECTION?
    Jun 2012
    514
    I have yet to get this to work on my haas post...i have several ops parts that this would come in very handy instead of the usual flood selection
    any ideas..
    thanks in advance :banana::banana:
    Big Chipin, spreading tha cheese, I be Big Chipin for days!
    bobcad guy Guest
    not sure what your asking, but m7 usually turns on mist coolant in my experience.
    Jun 2012
    514
    v25 has a selection to flood or mist or turn off coolant... when selecting your tools and doing tool paths.
    when i check it it does not work on the machine... i tried everything ...
    just wondering if anyone else has it working...i dont even see it outputting M07 int he post gcode...
    bobcad guy Guest
    then edit your post to output M7,my post is lines number 706, 707, and 708, to set m7 as mist. then, find out if your machine mister works with the M7 command by MDI'ing it, if so, your good, if not, you might need to set a parameter in your machine to accept M7 as the mist on
    Apr 2009
    3376
    My Haas does not have a Mister
  1. Mist vs Flood coolant
    By zamazz in forum Benchtop Machines
    Last Post: 05-16-2013, 04:09 AM
  2. How much air for mist coolant?
    By Memran in forum Benchtop Machines
    Last Post: 02-08-2012, 10:15 PM
  3. Coolant Through the spindle and mist
    By mecheng in forum Haas Mills
    Last Post: 08-26-2011, 05:44 AM
  4. flood and mist coolant
    By azza304 in forum Community Club House
    Last Post: 08-12-2011, 08:14 AM
  5. Mist vs. Flood coolant
    By rogerfries in forum Bridgeport / Hardinge Mills
    Last Post: 08-13-2010, 09:17 PM
