Hello all,
We have a Mazak horizontal machining center with an M-32 controller (or M-plus or Matrix Nexus) using G-code programming. I want to program a mill for spiral interpolation combined with helical interpolation to create a tapered bore.
I have the programming book, but I honestly can't make sense of the explanation, so I am going to take my best guess at most of the format and hope someone can help me with the rest.
Say the bore is a 10" diameter tapered .750" per foot on the diameter that's 1.000" in length. So the bore starts at 10.000" at the top, down to 9.250" at the bottom, using a 2" button cutter for the spiral/helical interpolation. X0Y0 is the C/L of the diameter. Z0 is the top face. So the program would look something like this:
(Start spindle and all that etc)
G17
G0X0.Y0.B0.
G43Z0.H1
G1G41Y-4.0000D1F50.0 (Go to start of arc)
G3.1X0.0000Y-3.6250I?.????J?.????Z-1.0000P.0500 (Arc ending point coordinates (X & Y) ... but I don't know what the I & J should be for this. Z is depth and P is the number of pitches (revolutions)).
G1G40Y0.
( Etc )
For I & J, would it be the distance from the starting point to the center of the arc at the start (Z0) or at the end (Z-1.0000), or neither? Also, would there be a problem using diameter comp for some reason? I don't know why there would be, but just thought I'd ask. I would just mess around with it at the machine to help figure it out but I can't get in there as they are running hot jobs.
Any help is appreciated. Thanks.
