586,655 active members*
2,935 visitors online*
    Jun 2012
    35
    Chinese Spindles 240v or 380v ?
    Hi all,
    Does anyone know off hand if the ebay Chinese spindles will work on 380v 3 phase Eu power or 240v, or do you have to specify which power you are going to use? I have a 380v 3ph in ABB VFD and wish to use a standard smaller spindle on it at times.
    Thanks in advance for an answer on this.
    Chris
    Nov 2006
    1036
    I'm not any kind of expert on this but I believe that spindles have rated voltages. Some are 220v some are 380v. I've seen some that are rated to use both. However, I don't think supplying 380 volts to a spindle rated at 220v will work.
    Can't you "program" your VFD to output 220 volts?
    Jun 2012
    35
    the lowest i can st it is 230v, is that ok?
    Jul 2009
    85
    Input voltage is proportional to output voltage. If you have 3 phase 480 then it will work also on mine i have it hooked up single phase 220v, it acts as a phase converter to 3 phase.
  1. Any reasonably priced (cheap) spindles other than the chinese spindles?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 11-05-2014, 11:16 PM
  2. Best Spindles for 240v 50hz electirity?
    By Litemover in forum Open Source CNC Machine Designs
    Last Post: 06-30-2012, 10:44 PM
  3. Chinese spindles
    By rozpiur in forum Uncategorised MetalWorking Machines
    Last Post: 10-09-2011, 03:08 PM
  4. Chinese Spindles
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-26-2011, 02:05 AM
  5. Chinese Spindles
    By kthomson in forum DIY CNC Router Table Machines
    Last Post: 02-16-2010, 03:46 AM
