586,546 active members*
3,295 visitors online*
    Sep 2011
    94
    connecting exteral run switch to vfd
    hello I have a hitachi wj200 vfd and I am wanting to wire a simple external switch however I cannot decipher the manual can anyone give me help.
    What I need is for it to run when two pins are shorted across and stop when they are not, I was able to set this up on my old huyongyang but cant get this one right.
    24223
    Very simple, place in external operation and close Input 1 to P24.
    Al.
    Sep 2011
    94
    After reading through my book again the guy who set this up for me wrote the same thing p24 to 1 and to set A001= 01 and A002=01 for terminal mode. Now when I jump the two connections the run light comes on but the spindle does not turn, Ive checked my parameters several times to make sure they took and ideas?
    Dec 2004
    783
    A001 needs to be at 00 to control rpm from the pot on the unit.
    Sent from tapatalk
    Sep 2011
    94
    Thanks guys I figured it out, I was just to tired last night to post about it, I really appreciate it will try to help some other people on the fourm.
  1. Connecting the on off switch...
    By Dubliner in forum Phase Converters
    Last Post: 11-23-2010, 09:08 PM
  2. Replacement for master switch/reversing switch on HF 8x12?
    By novahobbies in forum Benchtop Machines
    Last Post: 06-29-2010, 02:05 PM
  3. limit switch and home switch setup
    By Runner4404spd in forum CNC Machine Related Electronics
    Last Post: 12-15-2005, 02:58 PM
  4. Limit Switch / Home Switch in Software
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-02-2004, 12:58 AM
