586,396 active members*
3,079 visitors online*
Page 3 of 8 12345
Results 41 to 60 of 141
  1. #41
    Apr 2005
    253
    Looking good
    I'll get it finished sometime after I start it.....
  2. #42
    Mar 2010
    27
    Looks real nice :cheers: Any noticeable play in the trollies?
  3. #43
    May 2013
    204
    There's no play in the trollies, but I can hear when it rolls over chips that fall on the rails. that'll be fixed when I get the dust boot built and installed. I might also add a couple of compressed air lines to blow off the rails if the boot isn't effective enough. It'll all happen one step at a time.
  4. #44
    May 2013
    204
    This thing makes a mess, so here's some of the parts for a dust boot.
  5. #45
    May 2013
    204
    Scrapped the original plan and went with this dust boot/router bracket combination. No more smoke detector going off.
Name:	2013-07-17 22.35.19.jpg
  6. #46
    May 2013
    204
    My daughter wanted a bed for her american girl doll. Here's the headboard.
Name:	2013-07-27 17.10.36.jpg
    I'llrun the footboard and rails tonight so she can paint it tomorrow.
  7. #47
    Mar 2010
    27
    Looks good, what kind of wood is it? Did you cut it from 1 piece ?
  8. #48
    May 2013
    204
    That's a single piece of poplar.
  9. #49
    Jun 2004
    6618
    Yep. Poplar is paint grade. Looks great and kinda fools the eye.
    Lee
  10. #50
    Mar 2010
    27
    Very nice :cheers:
  11. #51
    May 2013
    204
    Here it is with the rails. Footboard tomorrow.
  12. #52
    May 2013
    204
    The whole bed.
  13. #53
    May 2013
    204
    I can post .dxf or gcode files if amyone is interested.
  14. #54
    Mar 2010
    27
    Turned out real nice. Now if I only had a big enough router to do it up full size
  15. #55
    May 2013
    204
    here's the dollbed drawing.
  16. #56
    May 2013
    204
    Made a sign....
Name:	2013-08-03 15.48.16.jpg
  17. #57
    Mar 2010
    27
    Looks real nice, great job
  18. #58
    May 2013
    204
    I need to run another one of these but I dropped my 60 degree v bit and it broke. Guess I'll run it again next week. I'm also working on a couple of jewelry boxes, a card case, a wood bowl, the list goes on and on and on. I've got the machine booked up for the next month.
  19. #59
    Apr 2007
    8082
    I have a machine that's big enough. My guest room bed is standard size and has a minimal cheap steel frame. I would like to replace it with something better, and larger.
    I've scaled the doll bed file to queen mattress size and made some changes to the looks. Mostly the foot board is shorter and the head and foot boards will be solid so that 3D carvings can be done on them. Final dimensioning won't happen until I have a new mattress to get actual measurements from. For now, I used the standard dimensions from charts I found on the web. The plan is to add some 2D carvings to the legs and rails, and 3D carvings on the head and foot boards before actually building it. Depending on which wood is used to build it the cost of the wood could get serious. Poplar or clear pine will work, and red oak would be very heavy and expensive, but that's probably the way I will go with it. Nothing will happen with this while I build a new frame for my big machine during the upcoming winter and spring months.
    Scaling it was easy enough. I'll look for the hardware that allows the bed to be disassembled. Or fabricate something simple.
    CarveOne
  20. #60
    May 2013
    204
    Glad i could give back. You are one of the few that offered advice during my build. I'd love to see some pictures of your new bed, carve.
Page 3 of 8 12345
  1. SHODA 5x router G-code samples
    By mihavin in forum CNC Machining Centers
    Last Post: 09-05-2013, 10:25 AM
  2. Mini CNC router samples
    By RoseChina in forum News Announcements
    Last Post: 07-25-2013, 11:17 AM
  3. Wood cutting/engraving samples made by thunderlaser
    By thunderlaser in forum Thunder Laser
    Last Post: 10-20-2012, 03:44 AM
  4. Dave's Build Thread
    By kemper45 in forum Momus Design CNC plans
    Last Post: 11-06-2011, 02:11 AM
  5. Signage Samples by LIMAC CNC Router
    By limacchina in forum Uncategorised WoodWorking Machines
    Last Post: 06-09-2011, 12:12 PM
