You may want to run some stringers inside the box between the x rails. Even consider adding skins to the top and bottom to make a torson box. Yes that gantry looks tall. I can ssure you that will deflect significantly. On this type of build I've seen people bolt on aluminum or iron angle to stiffen things up. THe way you mounted the leadnut to the gantry could use some beefing up as well.
Sorry for being critical. Been down that road with a similar type of build and want to save you some fustration before you bolt it all together.
