2 problems: First of all, I have air constantly leaking out of the top plate. Any ideas how to stop it? I have the air pressure at the correct setting as per the manual.
Second: I am getting a 185 alarm "A Cable Fault". All the cables are plugged into the right sockets. I have A-axis enabled, in parameter 30 I set the correct rotary table, I turned on the air brake. Any ideas how to fix this?
Thanks.
