586,655 active members*
2,370 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > First "real parts" made on the Torus Pro
    Mar 2011
    480
    I got my first opportunity to make a quick turn proto. on the Torus Pro.
    I designed an enclosure to house some electronics and a "boot" to cover the user access opening in the box. I made the box from HDPE. The box is roughly 3"x 2"x 1" with .050" thick walls. There is a groove on the face of the box made with a key way cutter to mate with the rubber boot. The assembly is held together with 2-56 Heli-coiled holes/screws. The box came out great, but then again, plastic is easy to cut. So the next step was to machine a core/cavity liquid silicone injection mold from aluminum to make the boot. The first attempt came out fantastic. The mold mating surfaces were faced with a .5 " end mill, and the contours were cut with both .25" and .125" ball mill. The surface finish came out ultra smooth. I used the mold straight off the machine to produce the rubber boots. No post processing required :banana: Very happy with the Torus so far .
    7063
    Looks nice!
    It's a great machine, isn't it? I could not be more happy with mine, and I've used it almost every day for the last 6 weeks, so I've got a lot of miles on it already.
    Ray L.
    Jan 2013
    263
    Looks really clean, good work.
  1. Torus Pro As A "Production" Machine
    By SCzEngrgGroup in forum Novakon
    Last Post: 01-16-2018, 02:14 AM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. Can Lego Mindstorms block run a "real" CNC?
    By rooftoplounge in forum DIY CNC Router Table Machines
    Last Post: 10-12-2011, 05:00 PM
  4. wanted a 8'x4'x 6" made a 13"x13"5"
    By krak in forum DIY CNC Router Table Machines
    Last Post: 08-25-2010, 04:58 PM
  5. First Part Cut on a real "Cheap CNC"!
    By paulried in forum DIY CNC Router Table Machines
    Last Post: 05-10-2003, 05:44 AM
