586,270 active members*
4,173 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Novakon Braking Resistor
Results 1 to 8 of 8
    Feb 2010
    73
    I added the optional Novakon Braking Resistor ($89 + shipping) to my Torus PRO mill. The results were amazing. The spindle use to take nineteen seconds to stop when spinning at 6000 RPM. The spindle now stops in less than one second.
    The movies show the results before and after installing the Braking Resistor.
    Novakon No Braking Resistor @6000 rpm - YouTube
    No Braking resistor @6000 rpm
    Novakon Braking Resistor @6000 rpm - YouTube
    Novakon Braking Resistor @1500 rpm - YouTube
    Braking resistor @1500 rpm
    Installation of the Braking Resistor was a breeze. Connect two wires to the Braking resistor and the other ends to the Sunfar C300 VFD, terminals P+ and PB. Program the Sunfar C300 VFD parameter F0.11 to “0.5”. That’s it! The Braking resistor only works with the Sunfar model C300 – It will not work with the model C300A.
    I strongly recommend the Braking Resistor as a big safety improvement to a CNC mill. Being able to stop the spindle in less than one second versus nineteen seconds is mandatory.
    Jun 2008
    1082
    Thanks for posting this - I was getting tired of the slow slowdowns too so I ordered one last week. It's bad when the longest part of a tool-change is waiting for the spindle to stop. Thanks for showing how easy it is to install and how well it works!
    [edit]Argh, I just saw that the braking resistor is/was backordered.[/edit]
    Have you also "fixed" the spin-up time setting in the VFD? If not: I would highly recommend it. Here is some discussion on how to do it - starting with this post by SCzEngrgGroup.
    Jun 2008
    1082
    Hmmm... I just looked in my cabinet and I have a "C300A" VFD. How certain are you that the braking resistor will not work with this VFD?
    (later...)
    I now see that same warning is in the Torus Pro beta manual. I also noticed they're using the same photos.
    I wonder why I have a lesser VFD.
    (a little later yet...)
    I emailed John at Novakon and asked if having a C300A did, in fact, mean I could not use the braking resistor. In very short order (~15 minutes) he emailed me back and confirmed that the C300A will not work with a braking resistor. It sounds like they are going to swap out my C300A for a C300. I imagine I'll have to pay something for the upgrade. John said he'd put something together tonight. What service!
    Of course, it would have been nice to know about this potential upgrade from the beginning. My order was pretty convoluted so I can understand how some things may have slipped by.
    Jun 2008
    1082
    I finally got my braking resistor installed! I had some delay because I was waiting for my C300 VFD to be shipped to me (it was gratis except for shipping, thanks John!)... I am also a procrastinator. Anywho, as expected: it works!
    I wanted to put it through its paces so I installed the heaviest tool I own: the Novakon "Mill Turn Chuck". The thing weighs over 2 kilograms! (Mine weighs precisely 2068.0 g. or approximately 4.5 lbs.) Below is a quick video I recorded of it spinning up to 6000 RPM and slowing down to a stop. This is with the C300 VFD parameters "F0.10" and "F0.11" set to 0.5.
    For my own curiosity I weighed a couple of my other large tool holders. My 5/8" keyless drill chuck weighs ~1.2 kg. and my 2" boring head with a random boring bar installed is ~0.95 kg. I also weighed a random ER-20 collet chuck; it was ~0.28 kg.
    I bought two braking resistors: one from Novakon and one that seemed to have "specs" that matched the C300 manual more closely. The one that is installed in this video is the non-Novakon resistor. I might switch over to the Novakon resistor though because it's larger - that makes me think it may dissipate heat more quickly. As a total novice and basing my opinion on appearance alone: I think the Novakon resistor is a better buy between these two. The Novakon resistor also has better mounts.
    Link to the same model resistor that I currently have installed.
    Link to Novakon's spindle braking resistor.
    Novakon Torus Pro CNC mill with braking resistor installed - 4.5 lbs. tool stops in 2.25 seconds - YouTube
    Sep 2006
    1738
    Thanks for posting the links. I would be happy with your video resistor displayed. Nice job.
    -Jason
    Jun 2008
    1082
    Thanks and you're welcome!
    Maybe I'm being dense, but I don't understand this sentence: "I would be happy with your video resistor displayed."
    Apr 2009
    123
    I wouldn't be spinning heavy lathe chuck to 6K RPMs. Keep it below 2K. If you lathe parts below 3/4" in diam simply use collect as a chuck (then you can spool to 6K).
    Jun 2008
    1082
    Thanks! I was planning to add something like "I don't know if it's safe or not, but I put in my lathe chuck and spun it up to 6000 RPM." but I guess I must have forgotten to. Not that I thought it would help very much, but when I did that test I wore my face shield.
  1. Braking resistor tip
    By LBodnar in forum CNC Machine Related Electronics
    Last Post: 05-16-2009, 01:24 PM
  2. Do I need braking resistors?
    By polaraligned in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-20-2009, 08:10 PM
  3. braking resistors.
    By najnielkp in forum Servo Drives
    Last Post: 07-07-2006, 05:03 PM
  4. Braking resistor question
    By Syp in forum Servo Motors / Drives
    Last Post: 01-21-2006, 04:52 AM
  5. dc motor braking
    By najnielkp in forum CNC Machine Related Electronics
    Last Post: 10-07-2005, 05:14 PM
