how do we go about using cutter comp? G41 and G42 and if someone could put up a sample program that would be great!
Cutter comp is a "machine" command. You setup the toolpath offset at the machine. Just make a single circle, then add a profile and on the patterns tab, select the machine compensation. The G41/42 will only output in the code when you select a lead in/out "other" than vertical.
