586,497 active members*
2,737 visitors online*
IndustryArena Forum > CAM Software > Mastercam > X6 High speed surfacing toolpaths
Results 1 to 9 of 9
    Oct 2010
    33
    Can anyone help me with X6 high speed surface paths? Seems to be quite different than the standard surfacing toolpaths.
    I have an issue where the tool wants to roll over the edge of a surface. If I try to select a check surface but some toolpaths don't support check surfaces and others treat check surfaces as drive surfaces.
    I could also make a boundary which seems to be the only option but to me is a pain in the butt and not very time efficient. I know in the standard surface toolpaths you could select this option (only between surfaces etc.) just wondering if there an option like this in the high speed surface toolpaths
    Thanks in advance
    Oct 2006
    104
    I use a tool containment boundry it is easier. select the model> select the containment boundry.
    cut parameters > tool containment > 3 options inside/center/outside.
    Mar 2012
    10
    Containment boundary is the quickest and easiest.. Under create there is silhouette boundary.This is what is used to make a quick 2d boundary of your part.There also is a c-hook called create boundary. I personally like this one better. It has more control(xy offset, z height, etc....)
    Apr 2003
    3578
    Also there is "Create boundary" that gives a different option on how to create the boundary based on tool size.
    The high speed I use all the time but some time the old paths must be used.
    Cadcam
    Oct 2010
    33
    Ok sounds like making a boundary is the only way. Thanks for the help guys!
    Just finished loaded and setting up X7...... Looks fun!!
    Apr 2003
    3578
    Make sure you get the download for SP1 after you start X7 and do not Migrate over.
    Been using for months like some of the changes.
    Cadcam
    Oct 2010
    33
    Quote Originally Posted by cadcam View Post
    Hmmmm...... when you say do not migrate over you mean all my config, posts and machine definitions? Crap I already did that.
    When I was using X6 the guy that got me up and going had added TP Sketcher to it. (very handy) do you know if it's available on X7
    Apr 2003
    3578
    Are you talking abot TP the option to crate paths by sketching?
    So when you did the install you told it to migrate all the posts and config info over?
    Cadcam
    Oct 2010
    33
    I had to tell it to do the migration. Under the File menu
    Yep the TP sketcher is just a free hand tool to make a 2d contour by eye. good for facing off an irregular spot
  1. High speed toolpaths
    By camtd in forum Mastercam
    Last Post: 01-06-2012, 07:06 PM
  2. High speed surfacing.
    By themuffinman in forum MetalWork Discussion
    Last Post: 04-28-2011, 07:07 PM
  3. NEW: TFM - Mastercam Surfacing High Speed Toolpaths Training CD
    By Mike Mattera in forum News Announcements
    Last Post: 07-14-2010, 05:30 PM
  4. Replies: 0
    Last Post: 07-14-2010, 05:28 PM
  5. High Speed toolpaths
    By Ford25 in forum Mastercam
    Last Post: 09-13-2009, 12:02 AM
