586,129 active members*
3,170 visitors online*
    Sep 2012
    MAX200 tripping switchboard breaker
    Hello
    I have a MAX200 that randomly trips a 56 amp d curve breaker when it goes to fire the arc. Have had a test meter on the cable and it trying to pull 577 amp from the mains(yep 10 X what the breaker is rated for !!! ), when it does fire it drops down to about 20 amps. Any ideas on what may be going wrong. It may do 28 starts then trips and then other time it has done 150 start before it trips again ...
    Mike
    Jan 2008
    2247
    Plasma systems have an extremely high inrush current....this occurs when the gas becomes ionized in the torch and a rush of current is needed from the power supply to maintain the arc.....the actual inrush current is probably closer to about 10,000 amps for a few line cycles. It is always recommended that you use either time delay fuses to accomodate this, or specify high inrush circuit breakers.
    This is a common occurence with any piece of equipment with a large inductive load. The reason for the random occurence is simply timing....the inrush current can be higher if the arc happens to fire right at the right point of the AC sine wave.
    Jim Colt Hypertherm
    Quote Originally Posted by Welding Mike View Post
    Hello
    Mike
  1. Hyd pump CB keeps tripping
    By eznight in forum Maintenance DIY Discussion
    Last Post: 03-18-2017, 04:01 PM
  2. Max200 - electric supply ELCB trips
    By joemic in forum Hypertherm Plasma
    Last Post: 11-08-2012, 11:29 AM
  3. Max200 Upgrade...
    By KilroyNo1 in forum Hypertherm Plasma
    Last Post: 06-04-2012, 03:01 PM
  4. Sare 750 with A2100 tripping main breaker
    By mgnbuk in forum Cincinnati CNC
    Last Post: 04-26-2012, 03:35 PM
  5. DM2800 5 amp breaker tripping
    By mp- in forum Dyna Mechtronics
    Last Post: 02-12-2011, 06:36 PM
