586,633 active members*
3,008 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > A4988 and this Japanese Stepper Motor strong enough?
    Hi all,
    First time trying out the A4988,
    Can I power these motors using the A4988?
    What will be the best voltage/current power supply to use.(3 motors on total using a db25 breakout board which accepts the driver).
    Next time how do I read and understand the stepper motor ratings...? just in case I get another motor or want to use a different driver.
    I plan on using it on a small desktop CNC hopefully for milling PCB...cutting plastics.
    Thanks!!
    Attachment 185754
    1695
    It should work. A 24v 2amp supply should be plenty for 3 motors. Be sure to st the motor currents to 1 amp.
    The important motor specs are torque, current and inductance. Try to find motors with inductance < 2mh. The lower the better.
  1. Replies: 0
    Last Post: 02-26-2013, 08:37 AM
  2. Integrated stepper motor? with built-in stepper motor driver
    By uirobot in forum News Announcements
    Last Post: 06-07-2010, 09:59 AM
  3. Need help to locate a strong stepper motor
    By Techbuilder in forum Stepper Motors / Drives
    Last Post: 10-03-2008, 03:09 AM
  4. How strong needs my stepper motor to be??
    By eagle550 in forum Linear and Rotary Motion
    Last Post: 06-10-2006, 02:30 PM
  5. Is this servo motor strong enough?
    By zorgzorgzorg in forum Uncategorised MetalWorking Machines
    Last Post: 04-19-2005, 12:44 PM
