Originally Posted by
KCSF_DUST_MAKER
I run a Biesse Rover 346 and a Weeke BHP-008 in a production shop and cut 3/4 MDF, melamine, osb, furniture grade ply and laminates regularly. My fave bit/feed/rpm combo on the Rover in 3/4" mdf is a 2 flute 1/2" compression bit, spun at 18,000 and fed at 18 meters/m. On the Weeke I have other tools to pick from and use a 3 flute 3/8 chip-break style bit on things that are going to be sanded anyway. I spin it at 20,000 and feed at 20 meters/m. For things needing a more finshed edge I use a 1/2" 2 flute 3deg down shear spun at 18,000 and fed at 15 meters/min. I would use a compression bit here but being a flatbed machine, ive had trouble with compression bits picking up parts and breaking the vacuum. Ive been begging for a 1/2" 2 or 3 flute down spiral to do this with but the powers that be think that chipbreak cuts just fine. The age old argument between operator and management.
