586,753 active members*
7,336 visitors online*
Results 1 to 9 of 9
    Sep 2010
    166
    Tormach passive probe setup.
    How do I figure out the effective diameter of the ruby probe tip? No such number was provided to me. So I used the 0.118" figure given in the manual; it also happens to be the diameter given by my indicator. So I assume it is the right number. Yet every part I have made using this probe is off by 0.04X".
    What number do I put into the mach3 software, and where? Tool 99 in the tool table?
    I have already completed the alignment procedure. After 6 iterations I got it down to 0 turns on each of the three screws.
    Dec 2011
    316
    Quote Originally Posted by mrquacker View Post
    Usually a two step calibration is required.
    1. Calibrate the probe itself.
    2. Calibrate Mach to account for probe overrun.
    Bear in mind that the probe travels a certain distance before triggering plus it has to stop once triggered.
    Generally the procedure calls for probing, for example the diameter of a known circle.
    If the known diameter is 1 " and with overrun, the probe measures 1.040, the software (Mach) must compensate for this.
    Sorry I can't give the specific Mach screen instructions to accomplish this as I run MSM (Calypso Ventures screen set) on a Novakon.
    MSM provides a calibration button to do this. (See attached screen shot)
    I am not familiar with the standard Mach screens so I can't help there.
    Perhaps someone familiar with probing on a Tomach will chime in.
    Trust this at least may be an explaination the 0.04x difference you are experiencing.
    John
    Jan 2012
    51
    The procedure in the manual is wrong, and will offset the probe by ~0.04". Set the probe in the spindle and rotate the spindle by hand - the runout of the tip will be obvious. There is a post here on the board somwhere that explains the new procedure.
    I centered the probe manually using a test indicator. Pretty simple process, and then you know the probe is centered.
    I was close to tears when I had the 0.04" problem with probe...
    Cheers,
    Geo
    Jun 2012
    311
    The process I use is:
    1) Adjust the probe to get it on center using a indicator and rotating the spindle. Somewhat tedious at first.
    2) Use a good edge finder and set x0 and y0 on a 123 block clamped in the vise. Use G54 work offset.
    3) Put the probe back in and change the work offset to G55.
    4) Use the features on the XY probing screen to set x0 and y0 on the 123 block. Check the difference between G54 and G55. Adjust the probe diameter value in the tool table and repeat.
    5) Repeat the process approaching the 123 block from the other directions.
    FYI The effective diameter is different from the measured diameter because some force is required to trip the switch, that force results in deflection in the long skinny shaft of the probe. More expensive probe styli use ceramic shafts to improve stiffness as well as reduce length variations with temperature change. Also the machine records the location at the time the probe trips not the location where the axis stops.
    I recheck the runout of the probe frequently as it will drift a few thousanths over time.
    Sep 2010
    166
    The response I received.
    According to the manual in section 8.2.2 the effective tip diameter is 0.1575" and the tool should be located in #99 on the Mach screen. I have attached this section from the manual for your convienience.
    Whatever. :/
    Clearly, I must be blind, as this is all just so obvious. /s
    Apr 2011
    720
    mrquacker,
    I don't believe the manual is saying the effective diameter is 0.1575, that's just the conversion of 4 mm to inch, in 4 decimal places. The effective diameter is going to have to come from the tip supplier, since as mentioned by IMT, it's a function of tip shaft length and material, as well as physical tip diameter. Hence the note in the manual section you are referencing.
    Terry
    Sep 2010
    166
    Yes, that is what I thought so too. As well as how all the pictures are for a steel tipped probe.
    But that is the tormach response I received. So I will give it a try and see.
    Jan 2012
    51
    Updated procedure I mentioned before:
    http://www.cnczone.com/forums/tormac...on_update.html
    May 2013
  1. Haimer Zero Master vs Passive Probe
    By FuriousGeorge in forum Tormach Personal CNC Mill
    Last Post: 02-15-2013, 03:24 AM
  2. Tormach Passive Probe - anyone tried it?
    By Jeff E. in forum Tormach Personal CNC Mill
    Last Post: 09-28-2012, 06:12 PM
  3. Learning How To Use The Tormach's Probe
    By twocik in forum Tormach Personal CNC Mill
    Last Post: 01-07-2011, 06:44 PM
  4. Tormach probe
    By Freddy Bastard in forum Tormach Personal CNC Mill
    Last Post: 08-06-2009, 09:07 PM
  5. Tormach probe?????????
    By highspeedmazak in forum Tormach Personal CNC Mill
    Last Post: 06-12-2008, 01:04 AM
