586,845 active members*
2,451 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma LB15 100-4 Diff Alarm
Results 1 to 20 of 32
    Jun 2004
    26
    I found 1 post from 2010 in search but did not resolve my issue. Anyway..
    This machine is a mid 80's LB15 OSP5000-G control.
    Problem: Z axis alarm out with 100-4 diff error. (Usually when cold. Machine does better at running temp)
    When I move the machine manually (pulse wheel) I can feel the axis motion stop. When the axis stops the Z motor is showing a 120% load. On the "Extend Data" servo screen I can verify the DIFF error... Of course if I keep going it will eventually alarm out due to the tracking difference.
    What I have done so far:
    1. Checked lubrication
    2. Checked for mechanical issues
    3. Checked cabling
    4. swapped the motor
    5. swapped the SVC board
    6. swapped the Drive
    7. swapped the drive power supply
    (luckly we had an old machine we parted out. However the parts ARE used.)
    Right now I'm still getting the same issues. No better/No Worse. Any other ideas?
    Feb 2009
    6028
    Sure sounds like a lube problem. Maybe coat the ways and ballscrew with VAC2 then try it? Is this a very old one with the Sanyo Denki motors or Okuma BL motors?
    Jun 2004
    26
    Thanks for the reply! These are BL motors. The ways seem to be getting plenty of lube. I can easliy move turn by hand when powered down. Movement is very smooth.
    Mar 2009
    1982
    You missed something, I guess.
    If the obstacle position is stable? Is it single one over the axis stroke?
    try to move rotating by hand as you did already at the problematic area.
    Jun 2004
    26
    I assume you are talking about optical position? It appears to be tracking ok.
    More info: On the Data screen the servo data
    RAPA:stops counting (assumed to be actual encoder position)
    RCON:continues
    Does anyone have anymore info on the "Data" screen?
    RAPA
    RCON
    RSVPVAR1
    RSVPVAR2...etc..etc
    Mar 2009
    1982
    optical position?
    no. Obstacle where the axis movement stops
    RAPA:stops counting
    that means: encoder is stall there, axis doesn't moves. check once again, if You can move axis by hand (machine powered off, of course) through this point. My guess, you have solid obstacle here
    Jun 2004
    26
    I can have the axis drive belt off and it does the same thing. So there is not obstacle. The motor just seems to electrically lock as certian points. Still nothing resolved on this.
    Feb 2009
    6028
    I'm assuming you changed the encoder with the motor?
    Mar 2009
    1982
    The motor just seems to electrically lock as certain points
    wrong presumption.
    don't take away the belt. Power off, try move the axis through critical point
    That makes a big difference. Are there multiple critical points, not a single one? Maybe encoder fault.
    Could be transmission, or maybe motor (mechanical) fault.
    Jul 2010
    287
    What mechanical errors have you checked?
    I would be curious if its a ball screw problem.
    If the catch is a mechanical catch you can feel by hand when turning the screw by hand, and there's no problem with the ways, then there's really only one other mechanical connection.
    I've seen a similar issue caused by 3 things, cracked casting/ways after a major crash; bad spot on the screw causing a binding; mis aligned screw from axis.
    I'd start by checking the screw for wear, then to see if they are linearly aligned.
    Just my two cents.
    Apr 2013
    16
    Re: Okuma LB15 100-4 Diff Alarm
    I have an identical problem with one '85 Okuma LB15. When RAPA stops counting, I have two situations:
    1. Motor load over 200%, even without belt, until DIFF is too big and I got 100-4 Diff Alarm
    2. Motor load over 200%, even without belt, but the motor at one point jumps (DIFF under 5mm), and I got a Zaxis servodrive error, and I have to turn off the lathe to get out of this error. So far, after this jumps, I had to replace two times a power transistor in the drive.
    Until now, I have done all geeserteg's steps, and for the moment I'm scratching my head.
    Any ideas?
    Mar 2009
    1982
    why did you took the belt away?
    are you sure, that mechanically the axis moves smoothly with no obstacles?
    Any ideas
    check all mechanical reasons of the stop and jump. What about tapered gibs?
    Apr 2013
    16
    Algirdas,
    Thank you.
    I think I found the problem. The Z-axis motor is loaded approx. 55% at 6m/min. Above this velocity, Diff Alarm occurs.
    Tracking back all problems, it sounds something like this:
    1. on February, we changed the TAC bearings on Zaxis ballscrew.
    2. on July, a small crash happened. Realigned the turret and replaced the lock washer on turret's axle.
    3. on September, one power transistor on BDU drive died, after several Z-axis servoamp errors. (IOCS lit) Replaced it.
    4. on November, again several Z-axis servoamp errors. The BDU was taken off, but found to be good. One of our engineers mounted it back, and bufff. The same transistor exploded(reversed B1 and E1 wires). replaced it. And another transistor dead. By chance, we had another one for spare and changed it again.
    While the drive was taken off, I have checked again the TAC bearings, and found them to be worn (grease turned brown), probably due to miss-alignment after the crash. Changed them.
    The lathe works, but under 6m/min and no G00. Changed the BDU with one from another LB15, but same result.
    Today, after a lot of meditation, probably I found the problem: Too much grease in the TAC bearings. On monday, I will clean them and will see if this is the cause.
    BTW, do you know what kind of VAC units was on LB15's from '89-'90? I bought one at an auction, and has the VAC drive missing. I want to buy one, but I don't know what type, as it seems to be a little bit smaller than the VAC's on the other LB15's that we have. Also, this lathe doesn't have the PSU above the CPU(probably inside),it has two BL-D 50A servo drives(smaller than BDU units), no tape-reader and load meters on the back, and the relay panel is replaced by a 2-level PCB.
    Feb 2009
    6028
    Did you megaohm the motor and cable set?
    Apr 2013
    16
    No, I don't have one. With a multimeter is OK.
    But I'm thinking that grease is the problem, because the load on the servo is raising proportional with the speed, and the error appear every time after raising the speed over 6m/min.
    I made a program to move back and forth the turret with 6m/min and worked for 30min without error. When I raised the speed with 10%, bang. error.
    With the same program, on other LB15's, the load is 5%, not 55%.
    Mar 2009
    1982
    it can't be because of "too much grease" if the grease is good. bad lubrication of linear guides; big wear of linear guides; significant misalignment of linear guides; and once again tapered gibs. Or maybe even some crack.
    Apr 2013
    16
    Algirdas,
    There is plenty of oil on the guides. It hasn't tapered gibs on z-axis, they are rectangular. No cracks, and load is uniform all over Z.
    I think I made a mistake when greasing the bearings, because I have filled them 100% with grease, and the bearings must be filled partially(discovered this later ). The grease is a lithium one, and may be a little thick.
    When I mounted those bearings on the ballscrew, the outer race was a little bit hard to rotate, even without preload, due to grease.
    Mar 2009
    1982
    check if it's possible to rotate the ball-screw by hand.
    check if there is no the exctra clearance of the saddle - the saddle movement must be smooth, no skew.
    Apr 2013
    16
    Yes, it rotates smoothly if I try to rotate it from the motor's pulley. If I try to rotate it from the ballscrew race by hand, it's a bit hard.
    Feb 2009
    6028
    Is the x axis drive the same as z? Might try swapping them, sounds to me like a bad drive or the turcite is gone on the z saddle. Grease may make it harder to move, but shouldn't cause this. It may heat up though. Did you re grind the collars, or at least double check the preload on the bearings? Those old ones typically need to be re fit with modern bearings.
  1. Okuma LB15 1-1 CPU Alarm (Cycle over)
    By Whitesquall9 in forum Okuma
    Last Post: 07-25-2015, 11:58 AM
  2. OKUMA LB15-II MW LATHE Alarm
    By energyzer in forum Okuma
    Last Post: 12-04-2010, 12:43 PM
  3. 100-4 alarm a diff over z
    By rev4q in forum Okuma
    Last Post: 03-05-2010, 08:02 PM
  4. Okuma lb15
    By firepoker1965 in forum Okuma
    Last Post: 09-23-2009, 02:01 PM
  5. OKUMA LB15 "ALARM 206 A Shear Pin 4"
    By RISNA in forum Okuma
    Last Post: 06-16-2008, 04:35 AM
