586,416 active members*
3,360 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > Water Jet or Fiber Laser Jet Laser Markable AL Sheet
    Oct 2011
    12
    Aluminum Legend Cutting Process - Looking for a best cost effective solution to cut blanks and cut holes into the flat blanks of Aluminum sheet per these features:
    Material - 0.020” thick aluminum laser markable (black anodined surface), has adhesive backer - Johnson Plastics AM5975
    We normally buy/use a plastic sheet from them to laser the whole pieces but this is a different application needing aluminum.
    Designs:
    1. Blanks - have have a 9-10 shapes but for example a 3" x 10" rectangle with corner radii - geometry from AutoCAD file
    2. Holes to be in Blanks - several holes and slots are cut into the blanks for toggle swtiches, push buttons, etc. - this configuration changes per order - geometry from AutoCAD file
    3. Laser Engrave Text by Holes - We place the machined legends in our bench top laser engraver to run the order's text program
    Our Current Cumbersome Process - We CNC mill the holes and then the outer profile from a retangle blank sheet. We then place the cut profile onto our laser engraver into a legend with corresponding cutouts to locate on the bed for lasering the text from an AutoCAD file.
    Volume - it is lower volume – approx.. 4-20/day.
    If need be I could buy blanks for the standard blanks we use to get away from that at least.
    Place blanks into a recessed pocket and tape the blank down to hold it. CNC the holes like today.
    Other options like lower cost fiber lasering or water jet cutting the blanks and the holes? Or other methods with our CNC mill?
    Brad
    Jan 2008
    20
    With that volume you probably going have a hard time justifying a machine purchase, you would probably be better off having batches done at your local waterjet or laser shop.
  1. CY Fiber Optic Laser
    By cavalier90 in forum Commercial Laser
    Last Post: 08-29-2013, 07:58 AM
  2. Durma Fiber Laser
    By snotkop in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-10-2012, 01:17 AM
  3. pulsed fiber laser cutting silver sheet
    By dcas1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-16-2011, 05:53 PM
  4. Replies: 1
    Last Post: 01-14-2011, 04:43 AM
  5. Laser + carbon fiber = ??
    By theclive in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-29-2007, 12:04 AM
