586,907 active members*
3,258 visitors online*
Results 1 to 20 of 35
    Sep 2012
    1543
    Lightbulb How do you clean your Tormach?
    How do you clean your Tormach? - YouTube
    Vacuum, Rag, Broom & Dustpan, or you just don't?
    How do you get the chips out from under your mill, or in those hard to reach spots?
    I needed to figure out something because I switch from Aluminum and Titanium alot, and can't contaminate my "batch" of chips since they are worth more when not mixed with other metals. Titanium scrap is $$$.
    So what do you do? This works great for me, but I'm always open to other suggestions, I prefer the easiest and cleanest approach to most things.
    -Brad
    Apr 2006
    439
    Hi Brad
    That is how I do it. I have an extra nozzle I stick a piece of silicon hose on and wash it down.
    I also have a mini dustpan and brush that fits between the machine base and chip trays that works really well for collecting the washed down chips.
    Scott
    www.sdmfabricating.com
    Sep 2012
    1543
    Hey Scott, I think the Silicon hose would be alot easier, I just had extra lengths of Loc-Line laying around so I used it, but using the coolant system has to be the easiest approach I can think of. I need to get a manifold attached so I can have multiple outlets on hand for use, Different Coolant Nozzles, a Cleaning Hose, etc. I have the valves, just no Distribution Block.
    Apr 2006
    439
    For my manifold I just added a short piece of alum. Threaded on the end and side for loc-line and the back to fit the stock pipe. I also treaded the bottom of the stock pipe for a ball valve with a stubby nozzle. This is where I stick the 1/4" Silicon hose . Without the hose it is still a pretty effective nozzle even from way up there.
    Scott
    Jan 2012
    714
    This is what I use, kind of a homemade "bib", keeps the chips on the table and not all over the machine, makes the cleanup much easier.
    I let them dry out overnight then vacuum the table the next day.
    98% of what I machine goes in the vise and the head clears the bib, if it hits it the magnets let go and nothing is damaged, just put it back in position.
    mike sr
    Jul 2006
    367
    Quote Originally Posted by BAMCNC.COM View Post
    A silicon hose works great. I use one on my mill with a regular garden nozzle ...
    pete
    Dec 2010
    1230
    Funny, I almost posted the same question this weekend. I do mostly aluminum, but have a production part that is delrin that I did on the X3 because it doesn't seem fun to try and get all the delrin out of the Tormach nooks and under the table.
    I tried filling a 2 gallon bucket with coolant from the LocLine and realized (1) it only kind of helped get the chips moving and (2) I was only getting about 45 gph from my coolant system. Ouch. I have been forced to use air to clear my parts since they have deep slots and the Tormach flood did nothing for removing chips. I removed the cheap "LocLine" Tormach provided and installed real ones without the hose inside (after drilling out the center of theirs and it barely helped). That got the Tormach system up to 60 gph. Fail. I am going to add a seperate tank and a 2800 gph dirty water sump to get the pressure high enough to use a garden sprayer like pete has and try to figure out a way to set two seperate drain lines so that I can leave tapping fluid in the small tormach one and Kool Mist in the big tank.
    Sep 2012
    1543
    Awesome ideas, the magnetic shield is a great addition too!
    Jun 2012
    111
    Quote Originally Posted by PriddyShiddy View Post
    Be forewarned, once you increase your coolant flow capacity, you will most likely overwhelm the mill's ability to drain, and have coolant leaking all over the place. Check out this thread. http://www.cnczone.com/forums/tormac...m_upgrade.html
    Jan 2007
    869
    I just use a vacuum, but I don't have flood either. I use a fogbuster for all my coolant needs.
    Wade
    Oct 2011
    477
    Sears Shop Vac - last about a year. If Sears sees it, they will not warranty - I don't even ask.
    nitewatchman
    Nov 2005
    157
    Same way as I clean the bridgy, the lathe, and the surface grinder - with an old Dyson.
    Been doing sterling service for over 10 years now on all sorts of wet/dry/oily swarf and grinding dust.
    Sep 2012
    1543
    Wow, that would be a good advertisment, that's like Al Bundy's car with a million miles.
    I have been using a Rigid 12 Gallon wet/dry shop vac http://www.homedepot.com/p/RIDGID-12...2#.UZPp0qLVB8E with a washable foam cover over the old paper filter frame for about 10 years. I would use a Dyson vac if Dyson made a wet/dry shop vac. I am not willing to use my Dyson DC 15 Ball vac http://www.amazon.com/Dyson-Floors-U...pr_product_top in the shop though :-(
    IMO Dyson is the absolute best vac there is. No filter to clog.
    Don Clement
    May 2011
    180
    I also use a Ridgid shop vac
    Sent from my GT-P5113 using Tapatalk HD
    Aug 2009
    294
    Quote Originally Posted by mike sr1 View Post
    I really like this idea. I almost didn't install my Tormach table enclosure since I was planning on fully enclosing it, but I'm glad I did. It keep most of the chips where it's easy to clean. This idea really adds to it. I also let my chips drain overnight, clean out the majority with a small dustpan and brush then vacuum. Cleans out almost all of it, and the chips don't clog my tank screen.
    Sep 2012
    1543
    That reminds me, my coolant screen ended up pushing through, so I pulled the bucket out and fixed it up. I had some large mesh screen laying around to put under the thin screen.
    Jan 2012
    714
    Nice touch on the backup screen, looks good!
    My screen had some holes in it from coolant or whatever so I replaced it with a stainless 40 mesh screen I found on Ebay, it was about 15 bucks to my door. It was a heavy duty variety as well.
    mike sr
    Jul 2013
    11
    Thanks to all for the great lessons here! I'm thinking about purchasing a Tormach 1100 by the end of the year and appreciate everyone's issues / workarounds.
    Sep 2012
    1543
    You found the right place, and no matter how good something seems, it can always be improved.
  1. Garage Clean out
    By nztomcat in forum Australia, New Zealand Club House
    Last Post: 01-25-2010, 08:36 PM
  2. clean up
    By Claude Boudreau in forum BobCad-Cam
    Last Post: 03-05-2009, 06:54 AM
  3. New X2, what now? How do I clean it.
    By chola in forum Benchtop Machines
    Last Post: 10-01-2008, 11:25 AM
