586,354 active members*
3,395 visitors online*
IndustryArena Forum > CAM Software > CamBam > Help, new to cambam, mach3 . . . .
Results 1 to 7 of 7
    Nov 2003
    9
    I finished making my homemade CNC Router and am starting to try to learn the software side of things, I have a licensed copy of Mach3 and using the trial on CamBam, I created a simple square in CamBam and created a simple profile and put the Gcode into Mach 3, this is what it looks like in Mach3, what's with the 3/4 circle at the bottom left corner ??
    I'm getting really bummed, I have a nice machine and have no clue what to do with the software.
    I'm getting this on other samples I am working with too.
    Pic of my CNC Router
    Attachment 184486
    Attachment 184484
    Apr 2003
    550
    That looks correct I suspect you are cutting an outside profile and the circle you see is your lead in and is part og the gcode created by Cam Bam....
    Work thru some of the samples..and watch all he videos. There was just a video posted on Cambam. Don't give up it gets easier as get a base understanding.
    Here is a link
    Cabin Fever Expo 2013 seminars Mach 4 CNC wizards
    note the only how to is the CamBam one..
    Garry
    Nov 2003
    9
    Thanks Garry.
    I did make some progress today and produced some good G-Code to make some new offset gantry sides for my machine.
    I made a nice magic marker holder for the router till my spindle and drive come in this week, and drew the part out on some construction paper, it came out perfect.
    Apr 2003
    550
    Glad to hear of the progress, sorry your nit getting more help on this. Post more pictures as you get some cutting done.....
    Nov 2010
    520
    I'm in the process of learning CAMBAM myself. You could try posting on the CAMBAM forum.
    CamBam - Index
    Nov 2003
    9
    Quote Originally Posted by RicknBeachcrest View Post
    CamBam - Index
    Thanks . . .
    May 2013
    I took of the way covers and found the problem.
  1. CamBam between Rhino and Mach3
    By arvidj in forum CamBam
    Last Post: 05-01-2013, 06:02 AM
  2. Need a bit of help on first cut CAMBAM,Mach3
    By idtat in forum Community Club House
    Last Post: 02-26-2012, 05:10 PM
  3. CAMBAM/MACH3 - no rapids...
    By wildwhl in forum CamBam
    Last Post: 03-11-2011, 07:36 AM
  4. Safe Z in cambam but not in mach3
    By bfcg in forum CamBam
    Last Post: 08-12-2010, 01:30 PM
  5. Is Mach3 best/only choice with CamBam?
    By Mecmac in forum CamBam
    Last Post: 02-05-2010, 03:51 AM
