The only thing holding the bed down on my grinder is gravity and the end covers.
Take off the end covers and the bed lifts off.
Say you were drilling a hole, and the thing feeds up the drill, then the table will lift.
Using it for engraving, though would be great or using tiny cutters that can't lift the table,
after you figure how to drive the table, of which mine is rack driven.
My Z ways on the grinder need linear guides now as the Z dovetail is just to crappy to be worth a refit.
Best thing I did to the little grinder is a add a VFD so you can grind stuff that typically melts.
Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
