586,103 active members*
3,667 visitors online*
    Sep 2011
    17
    Help Hypertherm 1650 slag
    Using a CNC profiling machine Powermax 1650
    Hypertherm PHC Height controller
    I am getting a lot of slag inside of the retaining cap of my Duramax torch.
    Getting error code 02
    Using 105 amp tip.
    Cutting 12mm plate.
    getting good cuts.
    but getting about 15 pierces, some times 4 pierces then have to replace the cap.
    Have tried adjusting the voltage from 145 to 156
    Any one have any suggestions.
    Staring to become costly
    Jim McFarlane
    Jan 2008
    2247
    If you can provide me some better details I'll be happy to help.
    - You say a 105 amp tip....do you mean nozzle? (some call the nozzle a tip, some call the shield a tip, some call the electode a tip)
    - Are you using the mechanized shield?
    - What part are you referring to when you say you have to replace the cap? Why are you replacing it?
    - What are your cutting specs on 1/2" steel: physical pierce height, physical cut height, actual cut height (did you measure it), inlet air pressure, secondary air setting (are you setting the secondary air with the torch air flowing?) , Amperage, etc.
    -Are you using the manual that came with the Duramax torch for these specs (the manual is on a CD and can be downloaded as a .pdf.)?
    -Any pictures of the parts after the 15 pierces...specifically the nozzle, the shield and the electrode?
    Jim Colt Hypertherm
    Quote Originally Posted by mayordrycreek View Post
    Using 105 amp tip.
    Cutting 12mm plate.
    getting good cuts.
    Jim McFarlane
  1. cut quality Hypertherm 1650
    By hok in forum Hypertherm Plasma
    Last Post: 01-18-2012, 03:07 PM
  2. Hypertherm 1650 fired
    By goyoasturias in forum Hypertherm Plasma
    Last Post: 08-16-2010, 12:53 PM
  3. Hypertherm Powermax 1650
    By unns_boy in forum PlasmaCam
    Last Post: 03-25-2010, 08:08 PM
  4. HYPERTHERM 1650 PROBLEMS
    By RCfabrication in forum Waterjet General Topics
    Last Post: 08-03-2009, 03:08 PM
