We would like to take this time to introduce our new CNC milling machine that is perfect for all shops and small businesses. A totally redesigned mill from the ground up using valued input from customers like you. Key improvements like rigid tapping, lever draw bar, servo axes, servo spindle motor, improved coolant containment system, wash down hose and much more.
Look over the attached pictures and action videos. Much is revealed from these picture and more information is forth coming.
Novakon Team
Washing the chips down the drain - YouTube
PULSAR Lever Draw Bar - YouTube
Pulsar SERVO features:
1. Spindle Head Specifications:
- 1.2 KW servo AC spindle motor
- 1-4500 rpm speed
- Rigid tapping standard
- Lever draw bar
- R-8 spindle
2. 25% heavier casting than Torus bed mill
3. P4 grade ball screws- 20mm diameter x 5mm pitch
4. Less than .0012” backlash
5. 220 VAC, 15A input power
6. Solid State limits sensors
7. One shot oil pump
8. Castings heat treated and sandblasted
9. Powder coated durable finish on sheet metal
10. Table Specifications:
- 15.75” x 9.5” x 12.5” work cube
- 200mm x 600mm table size
- Powerful axes AC servo motors- 1KW
- 500 IPM rapids
- Four, 7/16” T-slots (45mm spacing)
- Table work shelf
11. Stand specifications:
- Large 7 gallon coolant reservoir tank
- Coolant containment system included
- Sloping chip pan drainage system emptying under bed mill
- Two 90Watt coolant pumps
- Dedicated coolant pump with hose/spray gun for general chip clean up
- Large pull out chip collection drawer with filtration screen
- Easily moveable using pallet jack
12. Controller Specifications:
- PC with windows operating system (optional)
- BOB with automatic tapping switching capability
- Commercial servo AC drivers.
- Smooth Stepper inline controller (optional)
- MPG pendant with E-stop (optional)
- Transformer standard for 4th axis addition
- 4th axis stepper driver (optional)
