Thanks! :-)
Me and a coworker were talking about the cracked bearings yesterday and it turned out that he used to be an avid skater - he mentioned a skate bearing company I haven't heard about before: Bones Swiss
Looking at some skateboard and inline forums, everyone seems to swear on these bearings for their durability, so I looked at the company website.
Interestingly enough, this company refuses to ABEC rate their bearings:
Abec vs. Skate Rated? - Support - Bones Bearings
<Quote>
The dimensions and tolerances controlled by the ABEC standards include the diameters and widths of the raceways, their shapes to some extent and the smoothness of the running surfaces. The ABEC rating system ignores side loading, impact resistance, materials selection and grade, appropriateness of lubrication, ball retainer type, grade of ball, the clearance between the balls and the races, installation requirements, and the need for maintenance and cleaning. All these bearing design requirements are very important to the performance of your skate bearing, even though the ABEC rating says nothing about them.
<End Quote>
These are not cheap, about $40 for a set of 8 on Amazon. They have a lifetime warranty, which I probably won't take them up on if I break one, since it's not the intended use.
I just ordered two boxes and will replace the next ones that fail with these, hopefully they will last longer...
Mac
