I bought this 80w Chinese laser back in 2008 I think and it's been a real workhorse! Recently however it's been acting funny. Sometimes it cuts as normal, but other times the dimensions are off. Circles will be out of round and certain straight segments will suddenly have a slight angle to them. Also the engrave feature seems to have real problems; sometimes going off track for a line or two and other times the laser will simply not fire for a couple lines. Finally, when it gets all wacky the cut will be very rough instead of the normal smooth cut.
The laser is 80w and uses LaserCut 5.0 and the MPC6515 control card. I usually work in Corel draw, export a .dxf file and import it to LaserCut.
Attachment 183174
In this picture you can see one of the issues. The hole with the red arrow does not close correctly, while the hole with the green arrow does. The simple part is being cut multiple times using the Array Output function in Lasercut. So theoretically these parts should be identical.
Attachment 183176
Whenever this issue occurs the edge starts getting very rough. The red arrow is the bad edge, the green is the normal edge I get.
Very odd stuff, and I can't figure out where the problem is coming from. I can cut the exact same file and sometimes it works great while others it's nothing but trouble. Nothing has changed in terms of the ground, power supply, anything. Does anyone have an idea?
