"boat load of holes" - That just sounds wrong. LOL.
Floor standing drill press and tapping head. Spiral point for thru holes, and spiral flute for blind holes. Set your clutch for each type, and when the clutch slips throw the tap away. Trying to get, "just one more hole," will break your heart. The spiral point will cut easier AND take more abuse.
For each tap size take a new one and set the clutch so it just barely doesn't slip on your maximum depth hole for the material type. Then write it down in a little machining notes binder you should already have in your shop for reference charts. Note size, type of tap, and material. That way whenever you put in a tap, even a used one, you can set the clutch for it.
Bob La Londe
http://www.YumaBassMan.com
