I am going to use KFlop Step/Dir to Yaskawa SGDH servo drives in Position Mode for a vertical mill retrofit. These drives have outputs for differential encoder signals which I could send (singles) to KFlop. I have searched through the forums and I have read one opinion that there is no need to send the encoder signals to KFlop. But, I also read the KFlop can use encoder signals to keep position under certain fault conditions. Perhaps this is only desirable if you have glass scales etc. that are separate from the motor / drive electronics?
The Yaskawa motors have serial encoders, so I cannot power them separately - the only way I can get signals is through the drives.
If an E-Stop shuts down the drives, the encoder signals would stop. Perhaps a drive fault might stop the signals also?
I am not sure if only disabling the drives for E-Stop would be safe.
I have more research to do. I plan on using a Safety Relay and safe E-Stop practices.
Is there any benefit to having KFlop read the passed on encoder signals from Position Mode servo drives like these?
What E-Stop / fault wiring would be needed?
TIA
