hello, everybody I was wandering if some one can help with problem?, I have a .25 radios fillet between two sets of surfaces at aprox 30 degrees(red surface) so I created curves out of the fillets surfaces, using only the top edge for my 3d contour tool path, now the problem is that although backplot looks ok (the tip of the tool doesn't appeared thru the fillet surface)on verify i can see the gouge(pic 1), and with auto dif of vericut the gouge is aprox..05" I already tried to machine with surface finish(with the same 1/2 ball end mill i used for the 3 d contour) but i get more errors, and I think i am closer to get it right with the 3 d contour, the gouge is only in the first radios the second is fine, can anyone please tell me what am I doing wrong? or point me to the right direction, any input welcome, thank you in advance .
