586,437 active members*
4,229 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Cincinnati Milacron Arrow 1000 - Page Fault Exception
    Sep 2012
    Hello,
    New to this Forum, so excuse if I'm in the wrong state spot.
    Operated system yesterday and several times the following appeared:
    SEV_SYSTEM_FAIL_CHANNEL_ID
    0x80016
    (Interrupt Vector 14)
    Ran unit today, with no parts, cycled many times, no problem. But, as I reviewed the BIOS the Arrow suddenly stopped and displayed the above error.
    Anyone have any ideas?
    Juan
    Mar 2011
    463
    I replied to your PM already, but this could be caused by a number of things. Most common in have seen is RT Board, but never in the intermittent manner you described. Start by checking the voltages on your WS and RT batteries. Be sure not to remove them from the board while checking or you will lose the data they are protecting.
    You mention getting this error while reviewing the BIOS? This is a fault generated in Windows. Since the BIOS is accessed before loading Windows, I don't see how you could have received it at that time.
    Just a warning, I have seen customers corrupt their hard drive by shutting off the machine power when they get this fault. Sometimes there is nothing you can do since the control can not perform a normal shut down when the system is locked up, but just be aware that if the control is still accessing the hard drive when the power is cut, it can corrupt the hard drive.
    Re: Cincinnati Milacron Arrow 1000 - Page Fault Exception
    Hi every
    Any one help me. I need parameters cincinnati milacron Saber 1000
    [email protected]
    May 2006
    16
    Just received this,
    RT Board is Screen is Green the faults out with red page bellow when this happened.
    I am guessing corrupt hard drive
    Any advice?
  1. Cincinnati Milacron Arrow 1000 A2100 - relocated - HELP!
    By veggiedawg in forum Cincinnati CNC
    Last Post: 11-17-2022, 03:00 PM
  2. Cincinnati milacron arrow 500
    By shmoo in forum Uncategorised MetalWorking Machines
    Last Post: 12-10-2014, 10:33 PM
  3. Cincinnati milacron arrow 500 to pc
    By gazzaa in forum Want To Buy...Need help!
    Last Post: 01-20-2012, 07:30 PM
  4. Cincinnati Milacron Arrow 1000 setting 3 yrs...
    Last Post: 09-30-2011, 01:12 AM
  5. cincinnati milacron arrow 750
    By kevmor in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-06-2009, 08:26 PM
