586,655 active members*
3,171 visitors online*
    Apr 2013
    inches to degrees
    im working in polar interpolation on the sub side of a star sr-20 and weve been trying to figure out the correct way to find the feed rate while in polar....
    this is a swiss turn screw machine, im milling on the sub side with a high speed spindle at about 14 thousand rpms, using a 4 flute .055 mill. my smm(surface meteres per minute) is around 200mm(my machines in metric) milling in polar interpolation, this is no longer a linear move, wich to me means i need to transform my meters per minute into degrees per minute via the sub spindles rotation, or "c" axis.
    i gues in other words what im asking is,
    how do you convert inches/mm per minute into degrees per minute....
    Aug 2009
    684
    guesstimate the average diameter you are milling at
    diameter x pi = circumference
    circumference / 360 = distance per degree
    feedrate / distance per degree = feedrate in degrees
    DP
  1. inches to degrees
    By eloeffler in forum Mechanical Calculations/Engineering Design
    Last Post: 04-23-2013, 12:01 PM
  2. Replies: 4
    Last Post: 04-08-2011, 05:02 PM
  3. Help me understand feedrate for degrees.
    By g-codeguy in forum Parametric Programing
    Last Post: 09-23-2008, 04:13 PM
  4. Quadrant marks at 90 degrees
    By Mic6 in forum Haas Mills
    Last Post: 08-14-2008, 06:52 PM
  5. how do i get sweep to do more than 360 degrees ???
    By yamaha_r1 in forum Post Processors for MC
    Last Post: 09-21-2007, 03:41 PM
