Hi all
I have a set of normal manual router bits that I use(d) with the hand held. However there are a few project i have in mind that I would like to use some of the edge profiles with. However, as you well know, there is a bearing on the end. This can be removed BUT how do I compensate (may sound like a stupid question) for the bearing as the tip needs to be away from the wood as it isn't a cutting edge at all.
Have you done this? I am sure it's possible but how did you best compensate but still get the desired result? These bits have a 6mm or 1/4" shaft.
Thanks in advance.
