586,357 active members*
3,891 visitors online*
    Aug 2007
    9
    BIESSE ROVER - NEED HELP
    I am operating a Biesse Rover B 4.35. There is a glitch I can't seem to fix. The machine stalls in the "parked" position after the pedestal button has been pushed. After a waiting period of anywhere from 3 to 5 minutes and then pushing the pedistal button the machine responds and runs the operation. It doesn't seem to ever be a problem when the machine is first turned on and operating for the 1st hour of each day. It seems to be intermittent and add odd times. Has anyone experience the same problem? If so what was the solution?
    Thanks, Tom
    Dec 2012
    192
    While not in this particular machine I have already run into such problems.
    Your problem appears to be an aging component in the electronic cards. An idea would be to use a freezing spray. I mean the ones used for electronic failure detection.
    When the problem arises spray the cards carefully. First one by one so that you can locate the one that is failing. Then try regions of that card and finally chip by chip. If there are transistors, check them as well. The freezing spray cans almost always have a small plastic tube that can be attached to the spray tip. This should help isolating the offending component.
    If you decide on using any of these sprays please be advised to read the directions. In any case I would suggest using a mask and not breathing the mist.
    I hope this helps.
    Best regards.
    Aug 2007
    9
    Re: BIESSE ROVER - NEED HELP
    Thank you for your reply. Can you tell me the name of the freezing spray you are referring to. Also when I spray it onto the cards what am I looking for?
  1. cnc biesse rover 36
    By ylbermuhaxhiri in forum CNC Machining Centers
    Last Post: 01-30-2019, 10:30 AM
  2. Biesse Rover 16
    By Bris4051 in forum Biesse
    Last Post: 04-17-2015, 12:34 AM
  3. Biesse Rover 20
    By jondickson in forum Biesse
    Last Post: 03-07-2012, 09:11 PM
  4. Biesse Rover 322
    By metinjsh in forum Want To Buy...Need help!
    Last Post: 03-01-2012, 11:15 PM
  5. Please please help! Biesse rover a3.30
    By XMARTYX in forum Biesse
    Last Post: 02-01-2012, 11:54 AM
