586,430 active members*
4,130 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Weihong NCStudio to Mach3 conversion breakout board or smooth stepper
    Oct 2012
    5
    I'd like some advice on changing a router over from NCStudio using a Weihong PCIMC card to a Mach3 system using either a breakout board & parallel port or a smooth stepper board.
    The attached file shows what I have to work with and what I know of the existing setup.
    Can I just swap existing 15 wires into a breakout board or a smooth stepper and then configure Mach3 to suit?
    Any enlightenment greatly appreciated.
    Thanks Peter
    Attached Thumbnails Attached Thumbnails PJS Weihong Wiring Diagram .pdf
    Mar 2013
    35
    I would just keep the drivers and buy a BOB. I would suggest a PMDX-126 with the 107 spindle control board. This will be easy to hook up and work with Mach3.
    John
    Oct 2012
    5
    Thanks John,
    More specifically an I just swap existing 15 wires into a breakout board or a smooth stepper and then configure Mach3 to suit?
    Peter
    Oct 2014
    6
    Re: Weihong NCStudio to Mach3 conversion breakout board or smooth stepper
    Hi John you make it sound easy. I am no electronics buff but can follow a circuit diagram. can you advise connections for a Wiuehog NK105G2 DSP ControllerRegards David
    Sep 2014
    129
  1. Selective Soldering Robot Conversion to Mach3 and Smooth Stepper
    By phomann in forum RC Robotics and Autonomous Robots
    Last Post: 12-02-2013, 06:20 PM
  2. Smooth Stepper Ethernet Board - Mach3
    By mrpackethead in forum X3/SX3/G0619/G0463
    Last Post: 05-09-2013, 02:04 PM
  3. Replies: 1
    Last Post: 10-05-2012, 12:24 PM
  4. Replies: 0
    Last Post: 09-27-2011, 03:34 PM
  5. Smooth Stepper with a C23 Breakout board ??
    By GTRClive in forum Uncategorised MetalWorking Machines
    Last Post: 01-18-2010, 05:19 PM
