Just made a dozen of these little PITA parts. These are the little bits that lock the TTS holders into the carousel. They're among the few parts in the ATC that are made of steel.
Attachment 282666
I've also learned a few more things.... While an ATC is a wonderful thing, it also gives you many new and creative ways of screwing things up! Yesterday, I was making some parts, and needed to use a slitting saw. I setup the job, mounted all the tools, including the slitting saw, into the carousel, and clicked Run. The first several operations went great, and then it came time to load the slitting saw. The ATC picked it up out of the carousel, and proceeded to throw it across the enclosure. I thought "That's odd.... I'll have to figure out what happened there later on....". I manually mounted the tool in the spindle, and clicked Run, and the operation went fine, until it was time to change tools, at which point the PDB released the tool, and it dropped, crooked, into the arm, so I hit E-Stop. This is when I remembered that the slitting saw had nothing even remotely resembling an ATC groove in its holder! It can only be manually mounted. What a dumb-a$$!
A few days ago, I setup a job that required using the logical-to-physical mapping feature of the ATC. Only trouble is, I forget to setup the mapping table before kicking the job off. I can tell you, nothing good comes of that!
So, there are more things to remember before hitting Run, and more things that can go wrong, when you have an ATC. But, on the plus side, it is REALLY nice when it all works!
Today I also discovered, to my dismay, that in the process of adding the ATC communications to the PDB firmware, I seem to have broken something, as it misbehaved in a very odd way that I've never seen before. I'll have to get out my "PDB firmware debugging hat" sometime in the next few days and get that sorted out.
Ray L.
