Hello,
I have a 1998 Haas VF-4 with a rotary table. For some reason, for the past several months, every time I power off and power on the machine, the rotary table is disabled. (Parameter 43, 4th item down "DISABLED" is set to 1. When I enter a 0, then the rotary table is active and everything works fine. But, it is annoying that I need to do this every time I turn on the machine.
Do you know why the machine disables the rotary table every time it turns on?
Thanks for the help
