I'm noticing that the break angle parameter doesn't seem to be working as expected. Just as an example, I have a 90 degree turn made from 18 line segments...let's just say 20. So there's approximately 5 degrees between each line segment. My break angle is set to 10 degrees, but the motion still stutters around the curve unless I set the break angle to 15 degrees or so. I don't understand why.
I've included the file. Look at the curves near Y=0. It stutters around every one of those with a break angle set to 10 degrees.
Attachment 181240
edit: Sorry....meant to say near X=0. There are several 90degree curves in that area.
