586,160 active members*
3,559 visitors online*
Thread: yang 4th axs
    Nov 2009
    75
    yang 4th axs
    Dear All,
    We have a yang smv-1000 with fanuc 0-md controller My questions as below
    We tried change 900 option parameter for the 4th axis but all parameter change back to 0 again, why we can not change some option parameter?
    Yang SMV-1000 does not has 4 axis select button, after install 4 axis how can make zero point 4th axis, what kind of button we need or what? Or we will use direclty G28 A0.?
    We have another brand with Fanuc 0-M series taiwan cnc machine, we change 907.3 to 1 and D493.7 we shut down and open again this machine 4 axis is valid, about yang which diagnostic we need the change?
    Thanks&Rgeards
    Dec 2015
    Re: yang 4th axs
    Dear Freemanxxx
    I have same problem with yang 1000.
    I diagnosis should be changed so that the 4th axis is active ? thank you
    best regards
    Fabian
  1. Yang ML-25A
    By Billet Sean in forum Uncategorised MetalWorking Machines
    Last Post: 03-18-2015, 05:48 AM
  2. Yang MV-3A VMC
    By julioykaly in forum G-Code Programing
    Last Post: 07-07-2014, 10:30 AM
  3. YANG SMT 500
    By redatanger in forum Want To Buy...Need help!
    Last Post: 09-17-2013, 07:47 PM
  4. yang 4th axs
    By freemanxxx in forum Uncategorised MetalWorking Machines
    Last Post: 04-07-2013, 10:38 PM
  5. yang smv 600
    By eh1203 in forum Fanuc
    Last Post: 04-11-2011, 08:40 AM
