586,931 active members*
2,868 visitors online*
Results 1 to 8 of 8
Hybrid View
    Surface Grinder Help
    Hey guys,
    I've recently picked up a Parker-Majestic surface grinder. I'm trying to mount my wheels, and I seem to have a problem. I don't know how to mount the wheels nor do I think I have the bolts to do it. Can someone walk me through wheel mounting?
    Pics Below;
    ImageShack® - Online Photo and Video Hosting
    Mitchell
    Mitchell Parker
    Parker Precision Molding, Inc.
    Sep 2008
    117
    You need a wheel with a 1 1/4" hole as well as the appropriate adapter. Be sure the adapter has left hand threads. You'll also need the 1/2 inch left hand spindle nut to hold the wheel assembly to the spindle.
    Gene
    Jan 2010
    485
    Mitchell Parker
    Jan 2010
    485
    Well it would, but you will lose a lot of the use of the "Y" axis of the grinder. That link is to an extension for a spindle moves the wheel out by 2 3/8".
    Alright,
    Please excuse me as I'm still learning, but would this work on my grinder?
    Wheel Hardware - Wheel Accessories | MSCDirect.com
    It looks to be not as long at the previously posted.
    Mitchell Parker
    Jan 2010
    485
    That's what your after. But before you lock yourself into it, know that it is limited to wheels between 1/4" to 1/2" wide. If that works for you go for it.
    This one; Wheel Hardware - Wheel Accessories | MSCDirect.com is for wheels 1/2" to 3/4" wide.
    Ebay is where I'd go though. Here's a link to two of them for $75; Spoko Grinding Wheel Adaptors 2 | eBay There's many more on there too.
    Don't forget you will also need a spindle nut and a spanner wrench.
    Sep 2006
    6463
    If you haven't had any training on using a surface grinder, sign up for intensive care NOW.
    Ian.
  1. building manuel surface grinder and a od grinder
    By toolsrule in forum Benchtop Machines
    Last Post: 12-02-2015, 11:20 AM
  2. Kent surface grinder
    By amron in forum Uncategorised MetalWorking Machines
    Last Post: 01-18-2011, 09:44 PM
  3. j&s 540 surface grinder help please
    By MIKE JEFFERS in forum Uncategorised MetalWorking Machines
    Last Post: 08-03-2010, 08:18 PM
  4. Surface Grinder
    By gbowne1 in forum Uncategorised MetalWorking Machines
    Last Post: 02-28-2007, 06:28 AM
  5. Surface Grinder
    By itsme in forum Uncategorised MetalWorking Machines
    Last Post: 09-13-2006, 06:28 AM
