got a 1998 craftsman air compressor for free
says 5hp, 7.1cfm at 90psi (how do they do that with 15A at 115V?)
tank has rust on the bottom in several spots so i took the motor and pump off and the tank is on free craigslist now as scrap metal (drilled holes in it so nobody will use it for air)
i wish i could have used this for a compressor, i need a compressor like this bad...
oh well, the motor and pump seem in good condition and i know they ran because i did run the thing a couple days ago before i found the rust
so what can i do with them? my gears are turning..
i do need a vacuum pump and apparently you can convert these into one:
http://www.cnczone.com/forums/work_f...cuum_pump.html
but anything else?
i looked on sears website and they dont make the tank anymore..
is there some way i can grab a non-rusty, safe to use 20gal or similar tank somewhere for cheap?
or is there some other fun thing i can do with this stuff?
i also have an old but working pool pump with a similar sized motor..that would make a pretty good flood coolant pump right ? would 60gpm be enough for the sherline?
