586,799 active members*
3,088 visitors online*
    Aug 2005
    300
    Single line font
    Hi.
    I am not sure if this has been addressed but I am wondering if I could take my signature and change it to a DXF or some such so that I could machine it as a single line. when I try it now there are two lines.
    Ernie
    Aug 2012
    621
    Yeah, the vectorization tool recognizes each transition from black to white as a line, so a thin line vectorizes as two parallel lines. Easiest thing to do is just manually delete one of the lines.
    Luke
    "All I'm trying to find out is the fellow's name on first base" -- Lou Costello
    Aug 2005
    300
    Hey trotline,
    Do you see the red spot on my forehead? That is where I slapped myself. I never would have thought of that. I will try it tomorrow.
    Ernie
    Re: Single line font
    Google search CamBam Stick Fonts, a handy set of single line fonts free to download.
    I'm working on an elegant way to make single line fonts which look right from True Type Fonts, it is a bit of a faff but it will give a true representation with a single line, something deleting geometry does not do on anything but the simplest fonts.
  1. Russian single line font
    By kuki in forum Uncategorised CAD Discussion
    Last Post: 05-17-2012, 07:53 AM
  2. Single line font issue
    By pcbmiller in forum Uncategorised CAM Discussion
    Last Post: 03-24-2008, 08:06 PM
  3. SINGLE LINE FONT
    By xxshuaxx in forum Engraving Machines
    Last Post: 11-30-2007, 05:05 AM
  4. Single line font plt creator
    By Frost in forum Engraving Machines
    Last Post: 08-19-2007, 01:06 AM
  5. Single Line Font?
    By squarewave in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-30-2004, 01:03 AM
