586,655 active members*
3,982 visitors online*
    Jan 2006
    738
    Possible Extruder Design
    I had the thought of using a hypodermic needle as an extrusion tip. The needle itself would be the heating element. Place a small piece of copper tubing (perhaps turned on a lathe) over the needle and crimp the end near the tip of the needle. The attachment end of the needle would be one contact for power, and the copper tube would be the other. It would take a low voltage high current supply to power it.
    Mar 2013
    intersting...would you please upload some sketches of it....
    the second thought... is it possible to extrude plastic like the TIG welding does...shooting overheated plastic drops in high velocity...just thought
    Jan 2006
    738
    Well, did only have the drawings in my head... but... a few minutes with my CAD program and....
    I used a 20 gauge needle for illustration. A 20 gauge has an ID of 0.02375" (0.683 mm) and an OD of 0.03575" (0.9081 mm) so the wall thickness is 0.006" (0.1524 mm).
    The top ends of the copper tubing are clamped with 0.25" thick copper blocks for electrical and mechanical attachment and are identical.
    On the shooting of heated droplets.... I suppose it would be possible to do that similar to an inkjet. Might even be possible to electrostatic steer the droplets similar to the fashion that an electron beam is steered in a CRT. That could make for some really high speed high resolution print capability with a combination of mechanical movement and electrostatic steering.
    Jul 2007
    189
    You may want to check out the reprap extruder board
    Differences between types of extruders
    I read a post over there about extruder tip design
    It's quite critical to have the delivery tube and tip a certain shape and length
    If you have too much back pressure, the tip will continue to ooze when the print head is making a move from one place to another
    Even if you extract your filament to try and relieve that back pressure, it won't help
    I am experiencing just such a thing with my extruder design
    I need to rework my hot end from what I have learned on the reprap board
    I am up to 4mm extraction and still I have a bit of oozing and strings
    I am getting good print results other than that, but it's not good enough
    sublime on the reprap forum has spent a ton of time dialing in the ideal design
    here is his blog
    J-Head Nozzles
    Jul 2007
    189
  1. Extruder build for my CNC machine
    By EL34 in forum 3D Printer / 3D Scanner Discussion
    Last Post: 05-10-2013, 03:29 PM
  2. Extruder
    By SPEEDRE in forum 3D Printer / 3D Scanner Discussion
    Last Post: 02-19-2013, 04:32 PM
  3. Extruder/Hotend for $34 (Kickstarter)
    By Vulcan R&D in forum 3D Printer / 3D Scanner Discussion
    Last Post: 06-12-2012, 07:55 AM
  4. Toolpath for screw extruder on a lathe
    By pohon88 in forum Mastercam
    Last Post: 11-28-2011, 03:39 PM
  5. Homemade Aluminium Extruder
    By Russo08 in forum MetalWork Discussion
    Last Post: 11-23-2011, 05:20 AM
