586,461 active members*
3,681 visitors online*
Results 1 to 15 of 15
    Jun 2013
    24
    Mini Mill DRO, a different approach
    Rotary Quad Encoder + Arduino
    Video:
    More pictures: Mini Mill DRO Slideshow by WmCnc | Photobucket
    Just a proof of concept
    Wagner
    May 2005
    1397
    Re: Mini Mill DRO, a different approach
    Hey that's pretty neat. What model of rotary encoder did you use? And is that an Arduino or what?
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    Jun 2013
    24
    Hi James, thank you
    It is a 600 pulses per rotation encoder; got from eBay
    On the code, I count the encoder channels A and B on rise and fall, for a total of 2400 pulses per rotation.
    The processor is a Arduino mini-pro (5 V, 16 MHz).
    The display is a 4 digit I2c module, I will change it to a 8 digit SPI to show the + or - sign and 0.0005 position.
    Wagner
    Jul 2004
    13
    Very interesting project .can you open Arduino code and circuit diagram.
    Jun 2013
    24
    Hy qazplm800,
    The code can be found here: Mini Mill DRO
    The connections are indicated on the code.
    Also, see the full DRO: Mini Mill DRO
    Wagner
    Jul 2004
    13
    :cheers:
    Jul 2004
    13
    HI Wmcnc
    Thank you for your contribution and answer.
    my machine screw 4mm pitch / encoder pulse 500.
    ( Encoder factor (1/((600*4)/(12*0.08))*10000) )
    How to calculate change Arduino code.
    Best regards.
    tk
    Jun 2013
    24
    Hi qazplm800,
    On the equation:
    600 is the number of pulses per revolution of the encoder
    4 if the is the number of interruptions per pulse (The code measures the encoder lines A and B on rising and falling)
    12 is the number of teeth on the timing pulley
    0.08 if the pitch on the timing belt (in inches)
    10000 is the count on the display per inch of displacement
    Applying the equation, the factor for my machine is 4.
    1 inch of displacement will be 12.5 teeth on the belt (1 / 0.08). This will turn the pulley 1.041666 rotation (12.5 / 12), in a encoder with 600 pulses per revolution, this will generate 625 pulses (1.041666 * 600), times 4 interruptions per pulse, a total of 2500 counts. 2500 counts times factor of 4, gives the value 10000 (one inch, since the code puts a decimal point on the 5th display)
    If you need more help, please send more information about your application.
    Do you want to measure in inches or mm ?
    1/10000 or 1/1000 of a inch ?
    1/1000, 1/100 or 1/10 of a mm?
    Is your screw connect directly to the encoder ? No reduction ?
    Wagner
    Jul 2004
    13
    HI..Wagner
    my max7219 number left and right reversion.
    can tell me change this question Arduino code.
    yes screw connect directly to the encoder no reduction no pulley.
    I want to measure 1/100 mm.
    Best regards.
    tk
    Attachment 285432
    Jun 2013
    24
    Hello qazplm800,
    Nice picture.
    As I understand, your machine screw is 4 mm pitch, meaning that at one turn of the screw, your setup moves 4 mm and you want the display to show 4.00
    I also understand that your encoder generates 500 pulses per rotation.
    So, 1 turn = 4.0 mm, 500 pulses * 4 interruptions equal 2000 counts. To convert to 400 units, multiply by 0.2
    change the line:
    #define SCF 4.000000 // Encoder factor (1/((600*4)/(12*0.08))*10000)
    to
    #define SCF 0.2 // Encoder factor 4 mm pitch, 500 * 4 pulses/rotation 1/100 mm resolution (400/(500*4))
    To revert the display and move the decimal point to the 3rd display, change the display function (this is untested)
    change the function ThrDsp(void) to:
    void ThrDsp(void) // Display measure
    long v;
    int i,n,m;
    n=0;
    v=DroMea;
    if(v<0)
    n=1;
    v*=-1;
    for(i=0;i<8;i++)
    m=v%10;
    switch(i)
    case 0:
    case 1:
    lc.setDigit(0,7-i,m,false);
    break;
    case 2:
    lc.setDigit(0,7-i,m,true);
    break;
    case 3:
    case 4:
    case 5:
    case 6:
    case 7:
    if(m)
    else
    if(n)
    n=0;
    lc.setChar(0,7-i,'-',false);
    else
    lc.setChar(0,7-i,' ',false);
    break;
    v/=10;
    Good luck,
    Wagner
    PS. The forum messed-up the function text format. Missed the indentation.
    Please find attached the plain text of it.
    Attached Files Attached Files
    Jul 2004
    13
    Hi....Wagner
    Displays ten position only displays 1-9. not display 0
    I try to learning change Mill DRO Arduino code question.
    But i was kindergarten Arduino C language.
    max7219 number left and right reversion is my wrong PCB
    Could you tell me Change two problem.
    Once again thank you for your help.
    Best regards.
    tk
    Attachment 285690
    Jun 2013
    24
    Hi qazplm800,
    My mistake.
    Please change the code (on the function ThrDsp) from if(m) to if(v), as follows:
    case 7:
    if(
    v) // was if(m) before
    else
    Please let me know if this works.
    Wagner
    Jul 2004
    13
    Hello Wmcnc.
    Arduino DRO is completed.
    Thank for your contribution this DRO. and quick answers my question.
    Arduino DRO let me learn a lot. Again have a problem then help me.
    Best regards.
    tk
    Apr 2006
    7
    Hi the code working for me to, But I want to attach a steppermotor
    to the code, can any body help?
    Jul 2016
    1
    Hi..i am a new user here. I think your encoder generates 500 pulses per rotation. 1 turn = 4.0 mm, 500 pulses * 4 interruptions equal 2000 counts. To convert to 400 units, multiply by 0.2. Change the line:
    to
    china circuit board assembly
  1. Super Mini Mill 2 vs Mini Mill Tool Tracking
    By Terry G in forum Haas Mills
    Last Post: 05-25-2014, 06:55 AM
  2. best way to cut stock for machining on mini lathe/mini mill
    By crazybrit in forum Benchtop Machines
    Last Post: 12-31-2011, 10:40 AM
