586,903 active members*
2,671 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Question - Dealing with VMC1000/22 DX32 Tool Changer
    Feb 2009
    82
    Hello All,
    If I disable my tool changer by setting the number of tool parameter to zero (0), will the controller still recognize my tool table configuration and information?
    What I am hoping to achieve is when a T2M6 command is received, the spindle come up, and I manually change the tool (and continue) but the controller recognizes the tool #2 configuration I have loaded - I need to do the tool change manually until I get my TC fixed :-(
    Shaffin.
    It's very simple, eliminate that command ( T2M6), so the machine won't try to move the changer; by providing commands like G43 H2 ( G41/42 D2 for instance) it will recognize your tool offsets, in length as well as diameter.
    Mario
  1. Carousel Problem on VMC1000 TNC426 Tool Changer Not At Pocket Alarm
    By iknownothing in forum Bridgeport / Hardinge Mills
    Last Post: 07-30-2013, 05:36 PM
  2. Feeler VMC Tool Changer Problem - Urgent Question
    By digidem in forum Uncategorised MetalWorking Machines
    Last Post: 06-12-2012, 10:28 PM
  3. Bridgeport VMC1000 with DX32 issues
    By djbouet in forum Bridgeport / Hardinge Mills
    Last Post: 04-06-2011, 05:14 AM
  4. tool changer return question
    By Delw in forum Fadal
    Last Post: 12-02-2008, 06:54 AM
  5. Tool changer question
    By StormWerkz in forum Fadal
    Last Post: 03-31-2007, 10:34 AM
