586,792 active members*
2,748 visitors online*
    Apr 2009
    220
    Help turning motors C11 + G203 + Mach3
    I have the c11 bob from cnc4pc and the g203s
    I connected only the z-axis motor and configured the mach3 as shown in attached image.
    However, I am not able to turn the motor..I notice that it is a little warm,so I assume that it draws current from my driver.
    Also, I measured that G203 gets 48V and that the step,com,dir cables are already wired to the C11 bob.
    What else should I take care of to start turning this motor ?
    Thanks.
    Apr 2009
    220
    ...Should I load some g-code to make it turn?
    Jun 2013
    Re: Help turning motors C11 + G203 + Mach3
    I'm having the same problem... let me know if you fix it
  1. Gecko G540 mach3 setup motors not turning
    By Samvoodoo in forum Gecko Drives
    Last Post: 05-29-2013, 02:23 AM
  2. RESOLVED! Mach3 MaxNC enabled = 1/4 speed motors , Disabled = no running motors.
    By BIWVince in forum Mach Software (ArtSoft software)
    Last Post: 02-22-2013, 09:28 PM
  3. Mach3 Mill.... Motors not turning.
    By junior85 in forum Mach Mill
    Last Post: 05-29-2007, 07:45 AM
  4. Mach3 running my mill drill using the G203 Vampire drivers
    By Dan Mauch in forum Benchtop Machines
    Last Post: 11-15-2006, 08:15 PM
  5. Mach3 running the new G203 Vampire drivers
    By Dan Mauch in forum Gecko Drives
    Last Post: 11-15-2006, 08:00 PM
